Custom column configuration ability in Synchronized Items panel view
Victor Cheung
Member, Data Exchange Posts: 90
Hello!
This feature request is inspired by this: Support
If we have the ability to customize the field columns we want on the Synchronized Items panel, we could add the "Created Date" field and sort on that column, thereby finding exactly which item is the "original" item that all others sharing the same Global Id were reused from (directly or indirectly).
Thank You!
Thank You!
victor
Yes, customization is always nice to have. If designed properly this should not be difficult to add to the UI.0
