Focus stays on test-plan selected, instead of moving.
Marcel Bachus
Member, Data Exchange Posts: 29
When running a test-run from a test-plan by pushing the "play" button on the left of the test-run and the test-run window is closed (using "Save and Close" in the test-run window), the test-plan window gets reloaded, causing the focus reset to the start of the test-plan.
The desired behavior is that the focus of the test-plan window stays as it was, in order not having to scroll to the test-runs which were in focus each time.
Marcel Bachus
Innolux Technology Europe B.V
Agree that this would be very helpful0
