Risk management center - alternative display of content to overcome the limitation of Column width &
Lien Bäcker
Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 84
We are evaluating the risk management center.
One thing is troubling us, the limitation of column width. In some of these columns, only 10 characters per line. It is not really readable if there are more than one sentences in a field and also the Column would be too long that users need to scroll to read other information.
The second thing, if an item in a project is added through Add Link, during reviewing the risk item, user trying to open the linked item, they would be broad to item view in project, which is good but for the way back to the risk, they need to switch to other tab to get back the risk list and need also to search for risk item in the list.
So with both points, there are two feature requests
- to have a readable display for each cell in the risk item list such mouse hover and such read item view at the current trace view by clicking on a link.
- Risk Widget in Item View under project modus. The current Risk Counter in List View is a good start but it is not sufficient.
