Select fields for workflow locking
Jonah Caplan
Member, Data Exchange Posts: 43
When creating an item type, you can specify "required" or "suspect". It would also be nice to exclude some fields from system locking. Here's my scenario:
I have reviewed a bunch of items and marked them approved and applied a system lock and now I need to:
These are actions that are common to perform post-approval that are very tedious to get right with system locking and workflows.
- tag them
- sync the tagged items to Jira
- write the jira url into a field in the jama item
- unlocking the system lock manually, which is tedious given the current lock management UI and lack of method to re-system-lock the items easily afterwards
- move the items back to draft, perform the sync, and then move them back to approved
Jonah Caplan
QNX
QNX
Hi Jonah, I agree that it should be made possible to leave unlocked the custom fields used for categorization, assignment or prioritization.0
+1 for this, it would be very useful
Similar to the read-only field it could also be helpful to have an option for fields that are system locked in the UI, but still writable through the API0 -
Hi, I found an older request on same topic => +3:0
+1Alessandro
SICK AG0 -
+1 from us also0
