Possibility to see files attached to the test cases during test execution
Vladimir Cech
Member Posts: 183
It would be good if tester can open the original test case and see attached file(s) during test run execution. This was already discussed here https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?GroupId=7&MID=334&CommunityKey=4eac21f6-24d1-4f1e-92bd-76860b52af2c&tab=digestviewer but there is no final statement or solution. For some of our teams this is very important as they attached schemes, standards etc. that cannot be easily put directly to description or steps. Yes, it is possible to open second window with the test case but it is not comfortable and user friendly
Please add a possibility to see attachments in the original test case in Test Execution or Test Case tab during test execution - the visibility could be configurable.
Thank you for considering this idea
Vlada
