Possibility to see / filter tags in a list view
It would be good to have a possibility to see and filter tags on the list view. Currently tags cannot be added as a column and also it is not possible to filter based on them (quick filter) for list view.
Thank you for considering this idea
------------------------------Vlada
This is a good idea. Lack of visibility is one reason I avoid tags.
The second reason I avoid tags is typically I observe that only the person that created the tag will use the tag. Lack of visibility could be a cause for this behavior.
Jonathan LastName
IT Manager & Systems Analyst
Fidelity Investments
Merrimack NH
Sent: 11-25-2016 02:11
Subject: Possibility to see / filter tags in a list viewHi,
Vlada0 -
Our user community would like this feature as well since the Tags option is used regularly.
John
John Sarafin
UPS
Vlada0 -
I agree.
We also use tags.
I would like to see tags in filtered views.Ken G0 -
Agreed. We use tags often. Not having them in list view is driving users to export and work in rogue spreadsheets (not good).0
I agree. We use tags a lot and sometimes tag items temporarily such as when we need to group together a set of test cases for a specific project and need to remove those tags when we are done. Since you can only remove tags from one item at a item and cannot see them in list views, it is very cumbersome to edit and remove tags for multiple items. This has forced us to create a lot of custom fields which still don't give us the flexibility that tags do.vm
QA Supervisor
TaxAudit.com
California0
