"Assigned to" field changes in the previous version of the Test Run
we experience the following issue. Steps are:
- first person executes the test run; second person executes the same test run;
- compare 2 last versions of the test run, the last active person's name stands in both versions;
- no information about the change in the change details field;
Ekaterina, I have logged this defect as SOS-DEF-1977.0
Hello, this will be resolved in 9.1 when 'Assigned to' field for test runs is made into a fully versioned field, including activity logs and version history.
Ashley Ernst
CA
Sent: 06-29-2017 01:35
Subject: "Assigned to" field changes in the previous version of the Test Run
we experience the following issue. Steps are:- first person executes the test run; second person executes the same test run;
Ekaterina
Ashley Ernst
[Pronouns]
Product Manager
Jama Software0
