Error message when importing doors zip. What does this mean?
I am experimenting with the DOORs zip file importer. With one of the imports I am getting the following error message: Failure importing file: com.jamasoftware.contour.api.exception.DocumentNullOrInactiveException - A 'from' document ID must be specified to save this relationship. By hand editing the HTML export from DOORS, I have identified that one of three links in one of the objects is causing this error. There are 965 objects in the module I am importing and more than 1000 links.Here are things I have looked for and ruled out:
- The HTML syntax looks correct.
- The problem is not caused by one of the links being internal (i.e., starting and ending in the same DOORS module) because other objects have internal links and are not causing this error.
Hi Daniel,
Thanks for contacting us. For you to elaborate, could you file in a support ticket regarding this? You can also attach logs to it as well.0 -
I'm getting this same error message today. Do you remember how you overcame this one?
Connor Dregely
Maxar
Sent: 03-21-2018 15:04
Subject: Error message when importing doors zip. What does this mean?
Hi Daniel,
Justin Phang
Developer Support Engineer
Sent: 03-21-2018 13:36
I am experimenting with the DOORs zip file importer. With one of the imports I am getting the following error message: Failure importing file: com.jamasoftware.contour.api.exception.DocumentNullOrInactiveException - A 'from' document ID must be specified to save this relationship. By hand editing the HTML export from DOORS, I have identified that one of three links in one of the objects is causing this error. There are 965 objects in the module I am importing and more than 1000 links.Here are things I have looked for and ruled out:- The HTML syntax looks correct.
Daniel
