Version of test case in test run
Hello Jama staff and fellow Jama users.
Is there a way to see, which version of a test case is used in a test run?
Mari
Mari Leipola
Project assistant
Finland
    [Deleted User] Product Team Posts: 334
    edited January 2019
    Hi Mari:
    Good to hear from you again! Yes, while in Test Run execution you click on the next tab over: "Test Run Details", there you can find information on the Test Case, including the version. See below:
    Hope this helps,
    [Deleted User] Posts: 2
    edited January 2019
    Thanks again, Chloe!
  • David Allison
    David Allison Member, Jama Connect Interchange™ (JCI) Posts: 19
    edited May 2023
    It would be great if this information was provided at the test cycle level so all test case versions can be reviewed quickly. Having to go into the actual execution for each test case is cumbersome.
    David Allison
    Eargo
    Sent: 01-08-2019 08:51
    Subject: Version of test case in test run
    Hi Mari:
    Hope this helps,
    Sent: 01-08-2019 02:06
    Mari
    Mari Leipola
    Project assistant
    Finland
    edited May 2023
    Hi David,
    Thanks for your feedback! We're always open to looking at feature enhancement suggestions, and this sounds like a good fit for our Ideation module -- you can search for, view, and vote on submitted idea cards and, if there aren't any that encompass your feedback already, you can submit an idea card of your own by clicking on the orange Add button on the right-hand side HERE.
    Doing so would allow
     our Product team to learn more your usage case, as the Ideation module is specifically designed to facilitate conversations around the continual evolution of Jama Connect. Also, users can like and/or comment on any submitted card to reflect their support of that idea. Our feedback loop is outlined here: Product Ideation Process.
    [Due to the age of this thread, I'll be closing it]
    Sent: 05-17-2023 07:44
    David Allison
    Eargo
    Hi Mari:
    Hope this helps,
    Mari
    Mari Leipola
    Project assistant
    Finland
This discussion has been closed.
