Support for Tables in Test Case Steps
[Deleted User] Posts: 2
I have a need to have tables in the test case steps.
They are required to follow the company's style guide as well sometimes used to provide example output formatted in a clean way.
For now, I can create tables in another section, such as notes and then cut/paste that into the test steps... but it would be much easier for workflow and for on-boarding other employees if this could be added directly to the editor controls for test steps.
Would it be possible to enable the tables control for the editor used to edit test case steps?
Thank you kindly for you help!
    [Deleted User] Product Team Posts: 333
    edited April 2020
    Hi Korey:
    I am seeing two ways to do what you need: have a table available in the test steps.
    You can utilize these two icons (add a picture or add a file) in your Test Steps editor:
    this would be the result of each use case:
    let me know if you have any questions.
    edited April 2020
    Korey:
    I know I didn't directly answer your question about having the table controls in the Steps area of the Test Case. Right now, we do not have this capability. This would be a good Product Idea, as we are currently looking at different ways to improve the Test Center. I would suggest that you go to the Product nav tab and select Product Ideas, then make a post about this there. I will look for it and add this thread to it and/or give it an administrative "Test" tag.
    edited April 2020
    Hi, thanks for the suggestions.
    Unfortunately these won't work for us.
    Updating an image is too high of overhead and using a spreadsheet doesn't help for keeping our style guide (and we need to be able to export to Word with keeping good formatting).
    For now it'll have to be acceptable for us to create the tables in another section and simply cut/paste them into the steps.
    But if you would be able to request having the table controls added to the test case steps editor then that would be a big help in the future.
    Much thanks!
  • Victor Cheung
    Victor Cheung Member, Data Exchange Posts: 101
    edited February 2023
    Hi Chloe,
    In your reply you mentioned "You can utilize these two icons (add a picture or add a file) in your Test Steps editor: ", but I can't seem to find these icons when editing the Steps field for a test case.  It only seems to allow entering text:
    imageIs it possible to add images, active URL links (i.e. Richtext support) to the Action or Expected Result columns within the Step field?
    victor
    victor
    Sent: 04-21-2020 15:35
    Subject: Support for Tables in Test Case Steps
    Hi Korey:
    Sent: 04-21-2020 14:13
    Korey Conway
    OSI
    victor
    Hi Victor,
    The Jama Software User Guide article "Add images to test steps" would have the most updated guidance for this process, and I'd recommend checking it out if you haven't already!
    As this thread is a few years old, I'm going to close it but if you have any other questions on this, please feel free to file a Support ticket HERE to continue the conversation.
    Sent: 02-07-2023 09:57
    Hi Chloe,
    victor
    victor
    Hi Korey:
    Korey Conway
    OSI
This discussion has been closed.
