Velocity report with 8.49 - $DocumentSource.getDownstreamDocumentIds and .getDocument_DocAttachments
Lien Bäcker
Lien Bäcker Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 83
as preparing for update from 8.36.1 to 8.49, i'm converting our velocity from old to the new velocity.
With the old velocity
#set ($docDao = $applicationContext.getBean("documentDao"))
$docDao.getDocument_DocAttachments($testrun.id) gave me the list of all the attachments from the test run item
#set ($relDao = $applicationContext.getBean("relationshipDao"))
$relDao.getDownstreamDocumentIds($testrun.id) did gave me the list of id from downstream item (documented bugs) associating with the test run item.
but with the new Velocity -
$DocumentSource.getDownstreamDocumentIds and $DocumentSource. .getDocument_DocAttachments
always return  a empty array.
These functions work with other item types but just not with test run.
Please advice, with the new Velocity, how can I get the downstream, as well as attachment of a test  run.
Thanks much
    [Deleted User] Product Team Posts: 333
    edited June 2020
    Lien:
    Nice to see you again! Thank you for reporting this, this sounds like a defect we have just filed and is currently under review, where $documentSource.getDownstreamDocumentId no longer returns a value. For your records, the defect key is: SOS-DEF-4843.
    The workaround we have found is to: use $documentSource.getRelationshipsForDocument(Integer documentId, boolean isForward) that returns document_document objects and then get the .toDocument.
    I am relating your company with this defect and you can look for the defect key in the release notes for when it is fixed. Let me know if this workaround works for you.
    Sent: 06-18-2020 06:17
    Subject: Velocity report with 8.49 - $DocumentSource.getDownstreamDocumentIds and .getDocument_DocAttachments could not get the Downtream aund Attachment from items with type Test Run
    Thanks much
    Lien Bäcker
  • Lien Bäcker
    edited June 2020
    Chloe:
    Thanks for the workaround to get downstream items of a test run. It works.
    To add additional information to the documented bug, I tested $documentSource.getDownstreamDocumentIds (int id) with different item types. It works with other item types but not for test run. For test run, your suggestion is the solution.
    I find two more functions of $documentSource which do not work with the test run item type - to get attachment and to get versions. I'm looking for the workaround for these also.
    Item type: Test run
    other Item types such as Test Case
    To get Attachment using $documentSource. getDocument_DocAttachments (int id)
    Always return with empty array
    Works
    Result [DocumentDocAttachProxy{}]
    To get Versions using documentSource. getAllVersionsByDocumentId (int id)
    Works
    Result [VersionProxy{}, VersionProxy{}, VersionProxy{}, VersionProxy{}, VersionProxy{}, VersionProxy{}]
    [Deleted User] Posts: 71
    edited June 2020
    Thank you, @Lien, for point out those issues.
    We also experienced SOS-DEF-4843 and will see if the other functions are relevant for us as well!
  • Lien Bäcker
    edited June 2020
    Since $documentSource. getDocument_DocAttachments (int id) does not work for test run item type, what would be the workaround to get attachment for test run items?
    edited June 2020
    Lien:
    For the Test Runs try using:  .getRelationshipsForDocument instead of  .getDownstreamDocumentIds.
    Let me know if this helps,
  • Lien Bäcker
    edited June 2020
    Hi Chloe,
    the workaround you mentioned did help to get the downstream relationship of a test run.
    But I'm also looking for also a function to return the attachment of a test run, since $documentSource. getDocument_DocAttachments (int id) does not work for test runs
  • Christopher Nadler
    Christopher Nadler Member Posts: 6
    edited November 2022
    I am also looking for a function to return the attachments of a test run. It there any solution for this yet? Thanks in advance.
    I am using Version: Jama Connect 8.74.1
    Christopher Nadler
    Sent: 06-23-2020 07:35
    Lien:
    Sent: 06-22-2020 23:39
    Lien Bäcker
    Sent: 06-19-2020 01:46
    Thank you, @Lien Bäcker, for point out those issues.
    Anna Henke
    MeVis BreastCare GmbH & Co. KG
    Sent: 06-19-2020 00:52
    Chloe:
    Item type: Test run
    Works
    Works
    Lien Bäcker
    Sent: 06-18-2020 11:19
    Lien:
    Thanks much
    Lien Bäcker
    Alessandro Valli Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 840
    This problem seems to be fixed.
    Sent: 11-13-2022 23:44
    Christopher Nadler
    Lien:
    Lien Bäcker
    Anna Henke
    Chloe:
    Item type: Test run
    Works
    Works
    Lien Bäcker
    Lien:
    Thanks much
    Lien Bäcker
