Tag Cloud to be collapsed by default
Martha Fiske
Martha Fiske Member, Data Exchange Posts: 42
I have a user that wants to set the Tag Cloud to be collapsed by default.  I saw the below post, however it was written in 2017, and I can't find the settings mentioned there.  I there still a way to update the setting?
https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?MessageKey=97c9365f-40ba-425b-8664-2dc293575425&CommunityKey=c9d20d4c-5bb6-4f19-92eb-e7cee0942d51&tab=digestviewer
Martha Fiske
Lucid Motors
    edited September 2022
    The mechanism is the same, but the icon has changed.   In particular, in current versions of Jama, to the right of the project name, you will see an icon that is a rectangle divided into 3 sub-rectangles.   If you hover over that icon, the hover tip will say "Change layout".  Click on that, and you will get the dialog box described in the 2017 post.
  • Martha Fiske
    Thank you Geoffrey!
    Martha Fiske
    Lucid Motors
