Export a custom Word template, getting Table Headers right
R Brouns
R Brouns Member Posts: 3
Hello all,
I need some help with ensuring a certain format when exporting a Word document based on a Set of 'SRS' and using a custom template.
The problem is that I need:
  • General introduction chapters (TXT in FLD), just showing folder name + description --> works
  • Requirement chapters (SRS in FLD), exported into tables --> works
  • Each table in Item type SRS should have a TableHeader --> does not work
I cannot get the TableHeaders to repeat as desired. I understand what happens/why I get the wrong result, but need help with the correct Template markup.
What I like to get exported (but cannot get):
One header PER table
I come close, but do not get it right entirely.
I can get either one of the below, but not with a TableHeader per table:
1. Not right: No tableheaders
Exported from JAMA:
Uses template:
2. Not right: Too much tableheaders (per item)
Exported from JAMA:
Uses template:
Some other things I'm already aware of/tried:
  • I tried use the Mergefield TableStart:CHILDREN:SRS because this doesn't allow me to use another Table inside it (notice the TableStart:RELATIONSHIPS) as JAMA does not support nesting tables as I understood?
  • We are on Jama Cloud (not self-hosted), so I'm trying to use regular exports and not Velocity Reports. That's because for those, I understand I would need to work together with engineers on your side which requires more investment.
  • I put the TableHeader (on its own) in TemplateStart:FLD as sort of workaround. But that's not right either, as I get the header then also in the introduction chapters
Thanks for your help!
    R Brouns
    Microsure
      edited October 2022
      we had a similar issue and this is how it works for us:
      imageAs this adds the table header in all the chapters, we have added a macro to the template which removes all the tables with only one row when the document is opened for the first time:
          For Each Tbl In ThisDocument.Tables
              If Tbl.Rows.Count = 1 Then
                  Tbl.Delete
              End If
          Next Tbl
      But as you have already pointed out, this does not work with the relationship field included.
      Maybe the solution for you would be to take your 2nd example and write a macro which removes every uneven row (except the first) upon opening the document.
      Sent: 10-21-2022 01:24
      Subject: Export a custom Word template, getting Table Headers right
      Hello all,
      Exported from JAMA:
      Uses template:
      Exported from JAMA:
      Uses template:
        R Brouns
        Microsure
