marshalling data error message while saving test run results
Jeff Horacek
Member Posts: 5
Attempting to save results from a test run and receive "Error marshalling data. See the logs for more detail".
Anyone ever seen this or know how to resolve?
Jeff Horacek
STERIS Corporation
Mentor OH
Jeff Horacek
STERIS Corporation
Mentor OH
Hello, I juste have the same problem, no solution found for now... argh!
Julien SCHAER
Merck Group
Molsheim
Sent: 11-14-2022 08:56
Subject: marshalling data error message while saving test run results
Jeff Horacek
STERIS Corporation
Mentor OH
Julian,
I was able to find a work-around based off information I found here on the Jama Community. I did also create a ticket with Jama tech support and this is apparently a bug. They've assigned it a defect ID of SOS-DEF-6697 and indicated to look for this on future Release notes.
Work-around below:Medium
- SOS-DEF-6668 - Trace View & Coverage Explorer - Items with Matrix Lookup Calculations not showing properly and also exporting it
- Workaround - TBD
- SOS-DEF-6674 - API | PATCH/testruns/{id} unauthorized message when attempting to edit a read-only field despite API overwrite being enabled
- Workaround- Use the PUT function
- SOS-DEF-6697 - 'Error marshaling data. See the logs for more details.' error pops up when a custom date field is not filled on the Test Run
- Workaround - Set a date on the custom field
Jeff Horacek
STERIS Corporation
Mentor OH
Sent: 11-15-2022 23:09
Julien SCHAER
Merck Group
Molsheim
Jeff Horacek
STERIS Corporation
Mentor OH
Hello Jeff,
Thank you very much for your answer and the time spent on this problem.
Where can I set a date on the custom field? I don't find this field in my test run.
For information it's the first time I have this message error and it's systematic now.
Julien.
Julien SCHAER
Merck Group
Molsheim
Sent: 11-16-2022 05:42
Julian,
- Workaround - TBD
Jeff Horacek
STERIS Corporation
Mentor OH
Julien SCHAER
Merck Group
Molsheim
Jeff Horacek
STERIS Corporation
Mentor OH
Julien,
Apologies, but I don't have the answer to this question. I am not a business user of the software but am the system admin.
I will reach out to one of the business users that encountered this issue and request they send me some additional information which I will then post.
Jeff Horacek
PLM/ALM Administrator, Global CAD Administrator
5900 Heisley Rd.
Mentor, OH USA 44060
(M) 440 789-2629
Sent: 11/18/2022 3:41:00 AM
Subject: RE: marshalling data error message while saving test run results
Hello Jeff,
Julien.
Julien SCHAER
Merck Group
Molsheim
Julian,
- Workaround - TBD
Jeff Horacek
STERIS Corporation
Mentor OH
Julien SCHAER
Merck Group
Molsheim
Jeff Horacek
STERIS Corporation
Mentor OH
After start running the test case we will be updating the Planned Execution Date Field and then saving it to save the results without errors.
Jeff Horacek
5900 Heisley Rd.
(M) 440 789-2629
Hello Jeff,
Julien.
Julien SCHAER
Merck Group
Molsheim
Julian,
- Workaround - TBD
Jeff Horacek
STERIS Corporation
Mentor OH
Julien SCHAER
Merck Group
Molsheim
Jeff Horacek
STERIS Corporation
Mentor OH
