Creating a Template for Each Component/Sub-component Without Updating Item Type
I have a question. Would it be possible if we can create a template for each Component folder (Not for Each Item)
The only option I see in Jama is that I can update the fields for each item type and insert templates, but instead, I would like to a have template for each component/sub-component folder in the project structure regardless of the item.
Mohamed Elshal
LGC Biosearch Technologies
MN
Mohamed Elshal
MN
I assume that by "update fields ... and insert templates", you are referring to the "Editor Templates" that can be used for Rich Text fields.
For templates for Components (or Sets), you would create the templates in a "Template Project", and use re-use to instantiate those templates into your project.
Sent: 12-22-2022 12:36
Subject: Creating a Template for Each Component/Sub-component Without Updating Item Type
Mohamed Elshal
MN
Do you mean I need to create two different projects, one for reusing the templates I want and the other is for the actual project?
Mohamed Elshal
MN
Sent: 12-23-2022 07:06
For templates for containers (such as Sets, Components, and Projects), you would create the templates in a "Template Project", and use re-use to instantiate those templates into your project.
Mohamed Elshal
MN
Yes, although it's really N+1 projects ... N actual projects, and one additional project in which your set/component templates are stored.
Sent: 12-23-2022 07:14
Mohamed Elshal
MN
Mohamed Elshal
MN
