Requirement closure implementation
corrina benjamin
corrina benjamin Member Posts: 1
I am transitioning an existing aerospace V&V management tool into JAMA and have a few questions on how to get the functionality we are used to.
  1. My team has many requirements mapped to each test case. How can I show that 2 requirements have failed, while 5 have passed in a given test run? Currently all I can figure out how to do is mark the entire test run as passed or failed or passed with errors. I dont see a way to indicate pass/fail per requirement. What I want to show is that the test run was completed and mark which requirements are passed or failed.
  2. Is there a test case approval process implemented? We dont allow a test case (i.e. test procedure) to be executed until the test procedure has been approved and signed. Is this implemented/possible to enforce in JAMA?
  3. Is there a data review approval process implemented? Currently it looks like the requirements are closed after a test run is passed. We dont allow formal requirement closure until there has been a data review approval. Is this implemented/possible to enforce in JAMA?
  4. How do I show traceability from Test Cases to requirements (upstream relationship trace view)? Right now all I can figure out is how to show trace from requirement to test case, which is not the filtering I need to see. I need to see the rollup of all requirements into a few test cases.
Thank you!
Corrina
corrina benjamin
    edited January 2023
    Hi Corrina,
    Great questions! Our User Guide is a wonderful resource, and I'll link some articles from it that may be helpful here.
    1. In executing a test run, you should be able to mark each step as passed or as failed -- for more granularity, a custom report may be needed. 2., 3. By doing an Approval Review, the review would stay open until/unless the review moderator finalizes and closes the review. You can also opt for baselines to be signed electronically, if/as needed. 4. The Trace Matrix may give you something similar, as it'd allow you to select a list of requirements to see which have related test cases.  If you still have questions after reviewing those pieces, please let us know by filing a ticket HERE (making sure to include a link to this thread as part of the description). Our Support team would pick things up with you from there!
    Sent: 01-05-2023 09:32
    Subject: Requirement closure implementation
    Thank you!
    Corrina
    corrina benjamin
