Need to create an Export Template where There is a Space between the Different Items in a Project
[Deleted User] Posts: 13
I just want to add a space between the different items in a project when exporting to a word document. Is there a way I can do this using Jama? or do I need a Word Macro?
Mohamed Elshal
LGC Biosearch Technologies
MN
    edited January 2023
    Hi Mohamed,
    see here:
    Custom Word Template Easy Start Guide (jamasoftware.com)
    Is this what you were looking for?
    Sent: 01-12-2023 13:39
    Subject: Need to create an Export Template where There is a Space between the Different Items in a Project
    Mohamed Elshal
    MN
    edited January 2023
    So here I am adding space before template start but it is not working. Probably I am doing it wrong.
    Should I put the space instead before "TableStart" or "name"?
    Mohamed Elshal
    MN
    Sent: 01-19-2023 05:56
    Hi Mohamed,
    see here:
    Mohamed Elshal
    MN
    edited January 2023
    First of all, your example is missing the TemplateEnd for DEFAULTTEMPLATE and SET.
    And as described above, you have to use Shift+Enter and not just Enter to get the line break. It should look something like this (I haven't tried it):
    Sent: 01-19-2023 10:02
    Mohamed Elshal
    MN
    Hi Mohamed,
    see here:
    Mohamed Elshal
    MN
