dateTool in context sensitive velocity reports
Jeff Abbott
Jeff Abbott Member, Data Exchange Posts: 31
I am unable to get the $dateTool to work. I have a date field (revision_date) that I retrieve as $revDate. This then produces values like:
09/08/2022 04:00:00 AM UTC
However, I'm not able to use the dateTool to format the output.  The velocity report always returns the script text itself, for example:
<p>$dateTool.format('MMM d, yyyy', $revDate)</p>
Returns
Also, any call to $revDate.convertStringToDate() fails.
Jeff Abbott
Leidos
Orlando FL
    edited February 2023
    Hi Jeff,
    So that we can take a deeper look into this, can you open a
    Support ticket and reference this thread in the ticket description (as well as your version/type of Jama and any other pertinent info) on it, please
    Thank you!
    Sent: 02-07-2023 11:37
    Subject: dateTool in context sensitive velocity reports
    Returns
    Jeff Abbott
    Leidos
    Orlando FL
    I use a similar syntax as below in one of our templates and it works fine:
    #set( $rdate = $dateTool.toDate('dd/MM/yyyy hh:mm:ss a z', $revDate))
    #set( $revDate = $dateTool.format('MMM d, yyyy', $rdate))
    <p>$!revDate</p>
    Returns
    Jeff Abbott
    Leidos
    Orlando FL
  • Peter Lampacher
    Peter Lampacher Member, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 14
    Hi Jeff!
    I am using $dateTool.format('medium_date',$revDate,$reportLocale,$reportTimeZone)
    Be careful with timestamps as they are UTC in the database. This is why you shold pass a $reportTimeZone parameter. Example:
    #set($reportTimeZone=$dateTool.getTimeZone().getTimeZone("Europe/Vienna"))
    #set($reportLocale=$dateTool.getLocale())
    You can find all possible values for TimeZone here:
    What are the Java TimeZone IDs? | Gary Gregory (wordpress.com)
    I learned it the hard way...
    Peter Lampacher
    MED-EL
    Innsbruck
    Returns
    Jeff Abbott
    Leidos
    Orlando FL
    Alessandro Valli Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 787
    HI all,
    I was already sharing this in the past, maybe it is helpful.
    I normally use this :
    $dateTool.format("yyyy-MM-dd'T'HH:mm:ss", $dateTool, $dateTool.getLocale().forLanguageTag("de"), $dateTool.getTimeZone().getTimeZone("CET"))
    The only issue is the hard-coded time zone
    Returns
    Jeff Abbott
    Leidos
    Orlando FL
  • Jeff Abbott
    Thanks Patrick, that did the trick.
    Jeff Abbott
    Leidos
    Orlando FL
    Sent: 02-07-2023 23:07
    #set( $rdate = $dateTool.toDate('dd/MM/yyyy hh:mm:ss a z', $revDate))#set( $revDate = $dateTool.format('MMM d, yyyy', $rdate))<p>$!revDate</p>
    Returns
    Jeff Abbott
    Leidos
    Orlando FL
