I am unable to get the sortTool working
Jeff Abbott
Jeff Abbott Member, Data Exchange Posts: 31
I have this script snippet below. The $revList contains my itens, however I get nothing returned to my $sortedList:
#set( $revHistTypeId = 144)
#set($revList = [])
#set( $revHistoryDocInfoList = $documentSource.getDocumentInfoList($revHistTypeId, $project.id, 200) )
#foreach( $docInfo in $revHistoryDocInfoList )
#set ( $revDoc=$documentSource.getDocument($docInfo.id))
#set ( $success=$revList.add($revDoc))
#end
#set($sortedList = $sortTool.sort($revList,["revision_date"]))
Note that changing the last line to:
#set($sortedList = $sortTool.sort($revList,"revision_date"))
Does not help.
Jeff Abbott
Leidos
Orlando FL
    edited February 2023
    Hi Jeff,
    So that we can take a deeper look into this, can you open a
    Support ticket and reference this thread in the ticket description (as well as your version/type of Jama and any other pertinent info) on it, please
    Thank you!
    Sent: 02-07-2023 12:16
    Subject: I am unable to get the sortTool working
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
  • Peter Lampacher
    Peter Lampacher Member, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 15
    Hi Jeff!
    You are trying to sort document objects, but these do not have a "revision_date" property. This is probably why it fails.
    #set($sortedList = $sortTool.sort($revList,"createdDate")) will work. Or any other (sortable) property on document objects.
    Peter Lampacher
    MED-EL
    Innsbruck
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
  • Jeff Abbott
    Thanks Peter, how to I sort by a custom date field?
    Note, I only have to sort because the documents are not returned in the order they are displayed.
    Jeff Abbott
    Leidos
    Orlando FL
    Sent: 02-07-2023 23:40
    Hi Jeff!
    Peter Lampacher
    MED-EL
    Innsbruck
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
  • Jeff Abbott
    My 'hack' solution is to iterate the list in reverse since that is the order it is returned in using
    Jeff Abbott
    Leidos
    Orlando FL
    Hi Jeff!
    Peter Lampacher
    MED-EL
    Innsbruck
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
  • Peter Lampacher
    Hi Jeff!
    How to I sort by a custom date field?
    Retrieve the custom field values, find the right one and sort (possible with some extra code). The easier way would be to use a predefined date field (date1...date5) as these are directly accessible as document properties.
    If you want the items sorted as they are displayed in the Jama explorer: Retrieve the corresponding documentNode objects. These have sortOrder and globalSortOrder properties.
    Peter Lampacher
    MED-EL
    Innsbruck
    Sent: 02-08-2023 06:45
    Jeff Abbott
    Leidos
    Orlando FL
    Hi Jeff!
    Peter Lampacher
    MED-EL
    Innsbruck
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
  • Jeff Abbott
    Thanks Peter, I'll switch to use the date1.
    Jeff Abbott
    Leidos
    Orlando FL
    Sent: 02-08-2023 23:29
    Hi Jeff!
    Peter Lampacher
    MED-EL
    Innsbruck
    Jeff Abbott
    Leidos
    Orlando FL
    Hi Jeff!
    Peter Lampacher
    MED-EL
    Innsbruck
    #set($revList = [])
    #end
    Does not help.
    Jeff Abbott
    Leidos
    Orlando FL
