Sensible and performant way to descendants of an item the REST API
I have scoured the REST API documentation, and I don't see that there is any straightforward way to query for descendants or even just direct children of an item.
The only technique that I have been able to figure out to get those is to first retrieve ALL of the items in a project, then determine their containership hierarchies via location.parent
references, and then use that to identify which of the items are descendants of the starting item.
Is there something I am missing, or is that a capability that can be added to a future release?
Steve Jorgensen
Cliosoft
There is
<a href="https://rest.jamasoftware.com/#operation_getChildItems">GET /items/{id}/children</a>
as well as/downstreamrelated
and/downstreamrelationships
which should be helpful.
Colin Marquardt
Bosch Sensortec GmbH
Sent: 02-08-2023 14:20
Subject: Sensible and performant way to descendants of an item the REST APII have scoured the REST API documentation, and I don't see that there is any straightforward way to query for descendants or even just direct children of an item.
location.parent
references, and then use identify which of the items are descendants of the starting item.Is there something I am missing, or is that a capability that can be added to a future release?
Steve Jorgensen
Cliosoft
Hi Steve,
The most efficient way to fetch an entire subtree of items is to use the GET /abstractitems endpoint. You can apply two filters to achieve the desired result.- Use the project parameter to filter items from the current project.
- Use the contains parameter to filter items that match your parent items sequence number using Lucene search (https://dev.jamasoftware.com/cookbook/#abstract-lucene-parameters)
For example, to fetch all descendants of the item with sequence number 2.4 you would enter the following into the contains field: "sequence: 2.4.*"
I hope this helps.
Nick McHale
Team Lead - Software Engineer
location.parent
Steve Jorgensen
Cliosoft
------------------------------Nick McHale
Portland Oregon0 -
How did I manage to miss that? Thanks.
Steve Jorgensen
Cliosoft
Sent: 02-09-2023 00:24
Subject: Sensible and performant way to descendants of an item the REST APIThere is
Colin Marquardt
location.parent
Steve Jorgensen
Cliosoft
Does that mean that container parent/child is a kind of relationship that can be queried through /downstreamrelated ? How does that work, exactly?
Steve Jorgensen
Cliosoft
Colin Marquardt
location.parent
Steve Jorgensen
Cliosoft
Actually, I haven't used the last two endpoints myself, so I don't know.
Colin Marquardt
Sent: 02-12-2023 21:34
Subject: Sensible and performant way to descendants of an item the REST APIDoes that mean that container parent/child is a kind of relationship that can be queried through /downstreamrelated ? How does that work, exactly?
Steve Jorgensen
Cliosoft
Colin Marquardt
location.parent
Steve Jorgensen
Cliosoft
Great! I'll try that.
Steve Jorgensen
Cliosoft
Sent: 02-09-2023 09:19
Subject: Sensible and performant way to descendants of an item the REST APIHi Steve,
I hope this helps.
Nick McHale
location.parent
Steve Jorgensen
Cliosoft
That works great! The documentation could definitely be a little more clear regarding the behavior with respect to surrounding quotes, etc. Currently, some experimentation is required to figure out when surrounding quotes are needed and how they will behave.
Steve Jorgensen
Cliosoft
I hope this helps.
Nick McHale
location.parent
Steve Jorgensen
Cliosoft
parent/child is not a Jama Relationship, so /downstreamrelated and /downstreamrelationships would not apply to parent/child requests.
GET /items/{id}/children only gets the immediate children of the item, not the entire tree below the item.
So I believe Nick's suggestion is the only one that would apply to this use case.
Colin Marquardt
location.parent
Steve Jorgensen
Cliosoft
I tried the approach given above:
Use the GET /abstractitems using (literally, including quotes) "sequence":"2.*" to search for all items with a sequence starting with 2.*.
However, I also get item 3.2.* etc., so it also searches in the middle of the "sequence" field. Is there a key to signal that it must look only for terms STARTING at with 2.*?
Question to the Jama insiders: what version of Lucene is used?
I can find some information online about the syntax, e.g.
for version 2.9.4. This page does not mention any syntax to address the above issue and it explicitly states that the query can be subject to change between versions.Please help me out with this. Thanks!
