browser url not updated when clicking on test case from the test plan (test cases view)
Eric Roller
Eric Roller Member Posts: 5
A new jama UI tab opens for test case I clicked, but the browser url is not updated. Once in the jama UI test case tab I can click on the link under Project ID to show the correct broswer url for the test case even though it doesn't change anything in the browser view.
Maybe this isn't a bug, but it is very unintuitive. If I click on a test run from the test plan (test runs view) the test run opens in a new jama UI tab and the browser url is properly updated for the selected test run.
Eric Roller
Illumina
CA
    edited March 2023
    Hi Eric,
    Just to confirm, you're not seeing any errors or delays here, just that the URL showing in the browser doesn't update in the new tab that populates when clicking on test case?
    Sent: 03-20-2023 10:34
    Subject: browser url not updated when clicking on test case from the test plan (test cases view)
    Eric Roller
    Illumina
    CA
  • Eric Roller
    edited March 2023
    That's right. Only problem is the URL is not updated in the new tab.
    Eric Roller
    Illumina
    CA
    Sent: 03-27-2023 16:53
    Hi Eric,
    Eric Roller
    Illumina
    CA
    edited March 2023
    Thanks for confirming that. Are you trying to bookmark the URL of the tab that populates, or is there something else you'd be using the browser URL for?
    Sent: 03-28-2023 09:12
    Eric Roller
    Illumina
    CA
    Hi Eric,
    Eric Roller
    Illumina
    CA
  • Eric Roller
    edited March 2023
    We get the API ID from the browser URL.
    Eric Roller
    Illumina
    CA
    Sent: 03-28-2023 14:59
    Eric Roller
    Illumina
    CA
    Hi Eric,
    Eric Roller
    Illumina
    CA
    edited March 2023
    By API ID, do you mean the document key? We weren't able to reproduce the behaviour you've described, so I want to be sure to confirm what you're looking for in order to give you another way to find the desired parameter accurately.
    Eric Roller
    Illumina
    CA
    Hi Eric,
    Eric Roller
    Illumina
    CA
