treeLocation giving "The provided value is not an integer or exceeds the limit for 32-bit integers"
Abe Hudson
Abe Hudson Member, Data Exchange Posts: 3
I'm using the "api-docs" page in my cloud environment but getting  "The provided value is not an integer or exceeds the limit for 32-bit integers" error.
My api ids are 18000, 10003, and 18004, so they seem like valid integers. Is there something else that needs to be done for this to work?
Abe Hudson
    edited March 2023
    Hi Abe,
    Are you using a PUT endpoint to access treeLocation and, if so, how is that endpoint being written specifically?
    Sent: 03-20-2023 15:28
    Subject: treeLocation giving "The provided value is not an integer or exceeds the limit for 32-bit integers" error
    Abe Hudson
  • Abe Hudson
    edited March 2023
    Yes, I'm using PUT. Here is the curl command:
    curl -X PUT "https://mycompany-trial.jamacloud.com/rest/v1/items/{treeLocation}" -H "accept: application/json" -H "Content-Type: application/json" -H "jama-csrf-token: 575c5a1b-ee60-49f5-ac5e-9533ad55ed48" -d "{ "itemIds": [ 8004 ], "parentItemId": 10003, "insertBeforeItemId": 8005}"
    Here is the response:
    "meta": {
    "status": "Bad Request",
    "timestamp": "2023-03-28T18:52:07.914+0000",
    "message": "The provided value is not an integer or exceeds the limit for 32-bit integers. Please check your input and try again."
    I can use those same item IDs to successfully get information from other API methods, so I believe the IDs are not the issue.
    Abe Hudson
    Sent: 03-27-2023 16:29
    Hi Abe,
    Abe Hudson
    edited March 2023
    Thanks! I don't believe the IDs are the issue either, I was just wondering if the call was being done by using PUT /items/treelocation, or if there was a different format being used.
    Sent: 03-28-2023 12:00
    {  "meta": {    "status": "Bad Request",    "timestamp": "2023-03-28T18:52:07.914+0000",    "message": "The provided value is not an integer or exceeds the limit for 32-bit integers. Please check your input and try again."  }}
    Abe Hudson
    Hi Abe,
    Abe Hudson
    edited March 2023
    Note: There is a bug in the swagger treelocation documentation ... it says that the syntax is PUT /items/{treelocation}, when in fact it is as Carly has posted, PUT /items/treelocation  (i.e., no curly braces around treelocation).   From your example you posted, it looks like you were misled by that faulty swagger documentation.   Please let us know if it still doesn't work after you remove those curly braces.
    Sent: 03-28-2023 12:30
    Abe Hudson
    Hi Abe,
    Abe Hudson
  • Abe Hudson
    edited March 2023
    Understood. Please update the API-Docs "Try It" feature because it also is "hard-coded" to use the "{treelocation}"
    Sent: 3/29/2023 10:26:00 AM
    Subject: RE: treeLocation giving "The provided value is not an integer or exceeds the limit for 32-bit integers" error
    Abe Hudson
    Hi Abe,
    Abe Hudson
    edited March 2023
    Thanks Abe, and I can confirm we're working on updating the documentation accordingly.
    Sent: 03-29-2023 07:38
    Abe Hudson
    Hi Abe,
    Abe Hudson
