Replace with baseline, and deleted items
Francisco Espain
Francisco Espain Member Posts: 4
Hi, is there a way to actually go to the state where the baseline was created?
Currently, if you "Replace with baseline" you can revert the items to the state where they were in the selected baseline, but if an item was created after that baseline, that items continue existing.
Is there a way to delete all the items that are not in the baseline?
Francisco Espain
Francisco Espain
MPS
    edited April 2023
    Neither Replace with Baseline or Sync will delete any items or delete any relationships.
    Sent: 04-06-2023 08:10
    Subject: Replace with baseline, and deleted items
    Francisco Espain
  • Francisco Espain
    edited April 2023
    Hi Geoffrey, Is there another method to have all the items of a baseline, for example for a branch of the project from X baseline?
    Francisco Espain
    Sent: 04-06-2023 21:20
    Francisco Espain
    Francisco Espain
    MPS
    edited April 2023
    Engineering is currently working on a new "reuse from baseline" feature that I believe will provide the functionality you are looking for, but there is not yet a committed release date for this feature.   Until then, the best I know of is to write a custom report for the information you need.
    Cheers,
    Geoff
    Sent: 04-14-2023 07:35
    Francisco Espain
    Francisco Espain
  • Raphael Jurke
    Raphael Jurke Member Posts: 20
    I would like to add some more limitations of the "Replace with Baseline" function:
    1. Items that get regenerated after being deleted get randomly re-arranged out of order
    2. Links are lost
    Official feedback I have received has been to branch projects at milestones and put these branches into read only instead of using baselines…
