get same ID after a DOORS import
Jean-Michel RUFFLE
Jean-Michel RUFFLE Member Posts: 1
Hi all,
I would like to know if is it possible to get same Jama ID and DOORS absolute number after import a DOORS into Jama.
Inside Doors requirements, we have text of some doors requirements. Even if the setKey is different, we could do a find and replace. But after Jama import, all ID are different from DOORS absolute number. So it impact our specifications and code.
Best regards
Jean-Michel
Jean-Michel RUFFLE
    edited April 2023
    You can define the first two segments of a Jama Item ID (the project key and the set key), but you cannot define the third segment, which is the unique counter generated by the database.  You can define a custom field to hold the DOORS ID (this is commonly done).
    Sent: 04-14-2023 00:57
    Subject: get same ID after a DOORS import
    Hi all,
    Best regards
    Jean-Michel
    Jean-Michel RUFFLE
