Is it possible to compare items that are not synced across projects?
Aris Liokis
Aris Liokis Member Posts: 4
Hi everyone,
I was hoping that you could provide some help with the following issue.
I was wondering if there was a way to compare requirements across projects. The requirements were initially synced, however that was removed due to project changes.
Now we are trying to compare the two sets of requirements to identify what changes have been made in each project. Is there a way of doing that?
Thanks for the help,
Aris
Aris Liokis
Ultra Sonar Systems
WEYMOUTH
    edited May 2023
    You could generate a Word/PDF/Excel report for each set of requirements, and then do a Word/PDF/Excel diff of those reports.
    These compares of course cannot be as smart as the Jama compare when you had Global-IDs, but if you have not moved the items around in the hierarchy, you should get a reasonable result.
    Sent: 05-26-2023 03:17
    Subject: Is it possible to compare items that are not synced across projects?
    Hi everyone,
    Aris
    Aris Liokis
    Ultra Sonar Systems
    WEYMOUTH
  • Aris Liokis
    edited May 2023
    Hi Geoffrey,
    That is what I thought would be the case. Thank you for the reply, it's greatly appreciated!
    Aris
    Aris Liokis
    Ultra Sonar Systems
    WEYMOUTH
    Sent: 05-27-2023 08:26
    Hi everyone,
    Aris
    Aris Liokis
    Ultra Sonar Systems
    WEYMOUTH
