How to delete the content of a field on multiple items
arnaud laroche
arnaud laroche Member, Data Exchange Posts: 2
I would like to delete the content of a field ("description") of 70 items. The field is a fully customizable one (HTML).
I thought I could do that with a round trip export/import:
  • exporting the 70 items in Excel
  • making the cells of the column "description" empty
  • re-importing the field "description"
It doesn't seem to work.
Am I doing something wrong?
Thank you
arnaud laroche
  • Alex Frain
    Alex Frain Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 27
    edited June 2023
    I just tried this out in our Test instance running 8.79.3 and encountered the same "issue".  I performed a roundtrip export of some items, deleted the text from some of the items' description fields, and performed a roundtrip import.  The post import window indicated 0 items were updated and I confirmed none of the description fields were cleared in Jama.
    I did a 2nd test where I updated the text in the description for a single item in the roundtrip Excel file that was originally generated and left the description field cells blank that I cleared the first time.  I performed another roundtrip import and the single item whose description I updated did get updated in Jama but the items' whose descriptions I originally cleared in the Excel file were still not updated.
    The description field for this item type in our Jama instance is not set to "Required" so I would assume this should work.
    Alex
    Fujifilm Sonosite
    Sent: 06-23-2023 08:06
    Subject: How to delete the content of a field on multiple items
    Thank you
    arnaud laroche
    Alex
    Fujifilm Sonosite
  • arnaud laroche
    edited July 2023
    Thank you Alex for the confirmation of the "issue" in your environment too.
    Arnaud.
    arnaud laroche
    Sent: 06-27-2023 09:29
    Alex
    Fujifilm Sonosite
    Thank you
    arnaud laroche
