TestPlan - status
Jehoda Refaeli
Jehoda Refaeli Member Posts: 16
TestPlans can be sent for review, the test items can get included, but once the review is done, the TestPlan doesn't have a status field (or one that we can get to see).
The project can get obsolete testplans or rejected plans.
Is the status field missing? Is there a way to enable the viewing/changing the state of it?
Jehoda Refaeli
Uhnder
Austin TX
    edited June 2023
    In the Item Types tab of the ADMIN/Organization page, someone with Process Admin privileges can add a custom field (such as a Status pick-list field) to Test Plans.
    Sent: 06-24-2023 11:34
    Subject: TestPlan - status
    Jehoda Refaeli
    Uhnder
    Austin TX
  • Jehoda Refaeli
    edited June 2023
    Thanks for the reply.
    A. We tested trying to add a status custom field, but it won't let use 'status' as a custom field name.
    B. I do want to understand the rationale behind not having a workflow on test plans as any other item since they require approval as part of planning in ISO26262 and similar standards.
    Jehoda Refaeli
    Sent: 6/25/2023 3:08:00 PM
    Subject: RE: TestPlan - status
    Jehoda Refaeli
    Uhnder
    Austin TX
    edited June 2023
    A. You can use Status as the label of the field ... but you cannot use "status" as the unique-name ... just give it a non-default unique-name, such as "status1".
    B.  I do not believe there is a (good) reason for this not being supported ... just a limitation on how test plans were originally implemented.  So please feel free to request this enhancement at: https://community.jamasoftware.com/product-ideas-suggest/ideation-home
    Sent: 06-25-2023 15:20
    Jehoda Refaeli
    Jehoda Refaeli
    Uhnder
    Austin TX
  • Jehoda Refaeli
    edited June 2023
    Entered:
    https://community.jamasoftware.com/idea/testplan-workflowstatus-field
    Jehoda Refaeli
    Uhnder
    Austin TX
    Sent: 06-25-2023 15:34
    Jehoda Refaeli
    Jehoda Refaeli
    Uhnder
    Austin TX
