Jama Connect: Export ReqIf with requirement version and Folder Structure
Alexander Pekarovskiy
Alexander Pekarovskiy Member Posts: 1
We are trying to export system requirements using Jama Connect and have 2 issues
  1. We cannot export requirement Version
  2. We want to export folder structure for selected requirements (small subset).
For the second point, we tried to use the Location option during export, but in this case we export all the requirements in the uppermost folder. Baseline and Filter options don't export structure at all. Are there other alternatives to export the folder structure?
Thanks in advance!
Alex
Luminar
  • Alex Frain
    Alex Frain Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 27
    edited July 2023
    I'm not familiar with ReqIF exporting out of Jama but if it's similar to an Excel export where you specify the fields to be exported could you add both Heading and possibly Item Type fields to your export.  The Heading field would get you the hierarchy in a numerical format and the Item Type would just identify folder versus requirement granted the Project ID could be used to do the same.
    Alex
    Fujifilm Sonosite
    Sent: 07-06-2023 06:23
    Subject: Jama Connect: Export ReqIf with requirement version and Folder Structure
    Thanks in advance!
    Alex
    Luminar
    Alex
    Fujifilm Sonosite
