Creating a velocity report and including tags for items... Not same as other question that is lik
Scott Allen
Scott Allen Member Posts: 4
I'm trying to modify an existing Velocity Report .vm file.  I am able to add fields and move them around, but I want TAGS to also be part of the report for each item that has tags...
Attached is a segment of the .vm file I am using.  Look for where Scott (me) adds two fields, one of which is "tags".
thanks.
Scott Allen
Jet Propulsion Laboratory
Pasadena CA
    edited July 2023
    to get a list of all the tags of an item, you can try the following:
    #set( $tagDao = $documentSource )
    #set( $tagList = "")
    #set( $docTags = $tagDao.getAllTagsByDocumentId( $doc.id))
    #foreach( $dt in $docTags)
          #if( $foreach.first )
            #set( $tagList = "$dt.tagName")
          #else
            #set( $tagList = "$tagList, $dt.tagName")
          #end
    #end
    And then use the $tagList in your code. This should create a list of the tags like this:
    tag1, tag2, tag3
    Sent: 07-07-2023 12:48
    Subject: Creating a velocity report and including tags for items... Not same as other question that is like this...
    thanks.
    Scott Allen
    Pasadena CA
  • Scott Allen
    edited July 2023
    OMG Thank you.  It worked.
    Scott
    Scott Allen
    Pasadena CA
    Sent: 07-10-2023 07:04
    #set( $tagDao = $documentSource )#set( $tagList = "")#set( $docTags = $tagDao.getAllTagsByDocumentId( $doc.id))#foreach( $dt in $docTags)      #if( $foreach.first )        #set( $tagList = "$dt.tagName")      #else        #set( $tagList = "$tagList, $dt.tagName")      #end#end
    tag1, tag2, tag3
    thanks.
    Scott Allen
    Pasadena CA
