Show item fields when selecting an item in Trace View
Verena Neumaier
Member, Functional Safety Kit (FSK) Posts: 23
Is there a way to define the Item Fields that will be displayed in the following view:
When selecting an item from a Trace View, the item fields "Project", "Global ID", "Name" and "Description" are displayed (on the right side). Is there a possibility to display further Item Fields?
Verena Neumaier
Aktormed GmbH
You can control what appears in the columns with the "Set columns" operation, but you cannot control what fields appear in the right-side pop-up. But you can click on the ID at the top of that right-side pop-up, which will take you to the referenced item, and then you can see all the fields.
Sent: 07-17-2023 07:26
Subject: Show item fields when selecting an item in Trace ViewHello,Is there a way to define the Item Fields that will be displayed in the following view:When selecting an item from a Trace View, the item fields "Project", "Global ID", "Name" and "Description" are displayed (on the right side). Is there a possibility to display further Item Fields?Thanks!
Verena Neumaier
Aktormed GmbH
