Re-use library: preventing other projects from modifying items
I have a centralized library project. I want to reuse one item from it so that it is included in two other projects. How can I ensure that the content can not be modified by the two other projects, thus maintaining future changes from a centralized location (e.g. make it so that the only way to update the item would be through the centralized library project)?
Additionally, would it be possible to make it so that anytime a change is made from the centralized library project, it is automatically propagated to the other two projects (as opposed to being forced to sync the changes)?
Basit
To lock a single item, you can use a system lock based on workflow status. You will have to unlock it in order to update it.
The only way to trigger the change automatically would be to do so via a script (which you schedule to run periodically) or to use JCI.
Sent: 07-19-2023 10:09
Subject: Re-use library: preventing other projects from modifying itemsI have a centralized library project. I want to reuse one item from it so that it is included in two other projects. How can I ensure that the content can not be modified by the two other projects, thus maintaining future changes from a centralized location (e.g. make it so that the only way to update the item would be through the centralized library project)?
Basit
If I needed to prevent other projects modifying all of the items within a folder (rather than just one item), would a system lock still be the best option?
Basit Sheikh
Sent: 07-19-2023 21:18
Subject: Re-use library: preventing other projects from modifying itemsTo lock a single item, you can use a system lock based on workflow status. You will have to unlock it in order to update it.
Basit
If it is an entire Component or Set that you want to make read-only, then Project Permissions would be the way to go (a Project Admin would set those). But at the folder level, you would need to use System Locks on each of the items in the folder.
Sent: 07-20-2023 10:46
Subject: Re-use library: preventing other projects from modifying itemsIf I needed to prevent other projects modifying all of the items within a folder (rather than just one item), would a system lock still be the best option?
Basit Sheikh
Basit
