User has Creator License but cannot edit an item.
When user tries to edit item within a review - system returns message indicating she does not have permission, but when I check this user in ADMIN, she has Creator license.
Also when user tries to edit an item from explorer tree via the blue edit icon, there is no response.
Any idea what is going on? I asked her to logout and clear browser cache and login and try again, but to no avail
Anthony C.
One thing to check is whether the user has a floating creator license, and whether during that session, they were downgraded to a reviewer license because all floating creator licenses were in use. If that is not the case, I expect you will want to create a ticket for Jama Support to investigate.
Sent: 07-24-2023 15:06
Subject: User has Creator License but cannot edit an item.When user tries to edit item within a review - system returns message indicating she does not have permission, but when I check this user in ADMIN, she has Creator license.
Anthony C.
User has Creator license that is not the floating license, but the "fixed" license. I opened a ticket with Jama.
Anthony C.
Sent: 07-24-2023 21:11
Subject: User has Creator License but cannot edit an item.One thing to check is whether the user has a floating creator license, and whether during that session, they were downgraded to a reviewer license because all floating creator licenses were in use. If that is not the case, I expect you will want to create a ticket for Jama Support to investigate.
Anthony C.
Assume you checked if item was locked? And if they had permissions in that particular project?
Andrew MacCormack
LumiraDX
Anthony C.
------------------------------Andrew MacCormack
LumiraDX0 -
Sounds like she is not a user of the Project. Admin->Project->Users
Sent: 7/25/2023 10:25:00 AM
Subject: RE: User has Creator License but cannot edit an item.Assume you checked if item was locked? And if they had permissions in that particular project?
Andrew MacCormack
LumiraDX
Anthony C.
Yes, I checked that item is unlocked and user has permissions in that project.
Edit: I incorrectly assumed that since user has a Creator license, she automatically gets read/write access permissions. In her case, the group she belongs to is part of the project, but the group only had read access. I updated that permission and it works now. Thank you, @Andrew MacCormack
Anthony C.
Sent: 07-25-2023 07:25
Subject: User has Creator License but cannot edit an item.Assume you checked if item was locked? And if they had permissions in that particular project?
Andrew MacCormack
LumiraDX
Anthony C.
