Date as Item Field does not match in export?!
We have added a Field to an Item Type as "Custom Field" with the selection "Date". Therefore we can select a date from a calendar.
However, when we output this field with a Word export template, the date does not match. (The output date is one day earlier than the defined date in Jama).
------------------------------Verena Neumaier
Aktormed GmbH
Hi Verena,
I had a similar issue a while back. See here:
Velocity Reports: Timezone conversion with dateTool | Support (jamasoftware.com)
The problem is, that Jama converts the date to UTC time zone when exporting.
I had to add a conversion of the time zone to CET in our export template to solve this.
Sent: 08-21-2023 04:01
Subject: Date as Item Field does not match in export?!Hello,
Verena Neumaier
Aktormed GmbH
Patrick0
