Is there any way to block/forbid the download option ?
KUEN LONG LU
KUEN LONG LU Member, Automotive Solution Posts: 3
Dear whom it will concern:
Due to our company's policy, as an organization admin., I need to forbid all the JAMA users to export and download the documents even though they may be the editors or creators.
I want to allow the users to view, review and edit the documents through JAMA only.
Is there any way to block/forbid the export or download option ?
Thanks.
KUEN LONG LU
Functional safety expert for automotive electronic systems
Foxtron
    edited September 2023
    Hi there,
    One suggestion here would be to restrict the data access to a specific user group (which sounds like everyone but those who would be adding documents?) when installing the report (From Add/Edit Report, set the Data Access option to Limit data availability based on user permissions and set Restrict to Group to the created user group that contains those who shouldn't be downloading/exporting that report).
    Sent: 09-08-2023 00:07
    Subject: Is there any way to block/forbid the download option ?
    Thanks.
    KUEN LONG LU
    Foxtron
  • KUEN LONG LU
    Thanks for the reply.
    The problem is that the suggested solution suffers from the low efficiency. We need to configure all the report template each by each. Furthermore, any newly-added template will also need to be configured. If the configure is modified, then every template needs to be reconfigured...
    My idea is to add a new permission option termed "Export". Thus, organ admin can specify groups or users with three different permissions, i.e. read, write and export. Groups or users will not see the export button appeared on the view page if they don't have the "Export" permission for the viewing item or set.
    KUEN LONG LU
    Foxtron
    Sent: 09-08-2023 16:00
    Hi there,
    Thanks.
    KUEN LONG LU
    Foxtron
    Sure thing, and the desire to have a more bulk functionality is understandable. We're always open to looking at feature enhancement suggestions, and I'd encourage you to visit our Ideation module, which is a valuable space specifically designed to facilitate conversations around the continual evolution of Jama Connect. You can use the search functionality to see if your idea has been submitted by another user(s); if it is, then you can vote and comment on the card and, if it isn't, please post a new idea card there.
    Sent: 09-10-2023 23:32
    KUEN LONG LU
    Foxtron
    Hi there,
    Thanks.
    KUEN LONG LU
    Foxtron
