Velocity Excel report that has more than one sheet
Uwe Matzen
Uwe Matzen Member, Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 8
It it possible to write a custom Velocity report that exports to an excel containing multiple sheets ?
Uwe Matzen
Otometrics (Natus Medical Denmark)
    edited October 2023
    Yes, this is possible. You can start with creating the file with the sheets you need in excel, then save it as Single File Web page (file ending .mht) and then rename the file ending to *.vm.
    Inside the file, the sections are separated with "------=_NextPart_...." and each sheet should be annotated with sheet001.htm, sheet002.htm, etc.
    Then add your velocity code to the respective sheet.
    Sent: 09-29-2023 05:27
    Subject: Velocity Excel report that has more than one sheet
    Uwe Matzen
  • Sara Wertanen
    Sara Wertanen Member Posts: 5
    edited October 2023
    Do you know if it's possible to have the velocity report separate items based on folders into separate excel tabs? For example, I have a Set with 4 folders filled with items and I want each folder put into separate excel tabs. I would think it's similar to how velocity can do hierarchy based on folder level and turn them into headings for Word but I'm not sure how to apply that to Excel velocity exports.
    Sara Wertanen
    Oceaneering Entertainment Systems
    FL
    Sent: 10-02-2023 07:25
    Uwe Matzen
    edited October 2023
    This is probably not so straight forward, but you could maybe write a macro which creates a sheet for each folder. Difficulty is probably to let the code create the file list and the array of Tab names, which have to come at the beginning of the file.
    Sent: 10-02-2023 07:32
    Sara Wertanen
    FL
    Uwe Matzen
