Creation Rules with multiple Integrations
David Allison
Member, Jama Connect Interchange™ (JCI) Posts: 19
Right now, I have 2 active Integrations that write to 2 different defect folders (different field mappings) within my project. For each integration, I have created a creation rule based on Jira project names. I am guessing I may not have this set up correctly. From within a test run, if I create a defect, select the Jira project (from a pick list) and submit, it creates the defect in the folder defined in the 1st integration (see below) and it is not shared with Jira. Does anyone have any suggestions or is this a bug?
1st Integration:
Creation Rule for 1st Integration
1st integration Field Mapping:
2ndIntegration:
Creation Rule for 2nd Integration:
2nd Integration Filed Mapping:
David Allison
Eargo
