Not Applicable Option in the Test Run Status /Option to delete the test case from the Test Group.
Nikhil Gupta
Nikhil Gupta Member Posts: 1
Hello, we are using the latest version of JAMA Connect ( 9.4.0).
1. We have an issue and want to understand if we can have an option of "Not applicable" test status under the Test run. Idea behind that is when a test group is selected from a bunch of test cases and if the tester wants to run only the particular number of test cases and we should make the other test cases as not applicable instead of keeping as "Not run" . This would help us to report the status as "Not applicable" as those are not applicable for that particular build.
2. Also if there is an option to delete the test case from the TestGroup, so we can have only the applicable test cases under the test Run.
Any of the above options will help us in the keeping and tracking our progress status properly in the meetings.
Nikhil Gupta
Lucid Motors
  • Anthony C.
    Anthony C. Member, Medical Devices & Life Sciences Solution Posts: 25
    edited October 2023
    I am an organization admin for our Jama instance ( Jama Connect 9.5.0).
    I can set the test status field to include N/A through ADMIN menu.
    I can also delete test cases from a test group, and it does not need to go through ADMIN menu.
    Anthony C.
    Sent: 10-11-2023 10:12
    Subject: Not Applicable Option in the Test Run Status /Option to delete the test case from the Test Group.
    Nikhil Gupta
    Lucid Motors
