Baseline Source data using Velocity
I'm creating a velocity report that exports baseline information. I'm am wondering if there is any way to get data about the baseline sources (name and key). This data is readily available through the Rest API but I'm struggling to find any information when using velocity.
Is there any way to retrieve baseline source data when generating a report using velocity?
------------------------------Adriaan Arnason
Process Engineer
Össur
Peter Lampacher Member, Jama Connect Interchange™ (JCI), Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 14
Hi Adriaan!
You can read the refId and scopeId properties from the baseline object. These refer to the baseline source.
Hope this helps.
Peter Lampacher
MED-EL
Innsbruck
Sent: 10-24-2023 09:15
Subject: Baseline Source data using VelocityI'm creating a velocity report that exports baseline information. I'm am wondering if there is any way to get data about the baseline sources (name and key). This data is readily available through the Rest API but I'm struggling to find any information when using velocity.
Adriaan Arnason
Process Engineer
Össur
Hi Peter,
Unless i'm mistaken, those properties refer to origin of the baseline, not the baseline source.
What I'm looking for is the baseline source information as presented in the baseline tab.
If you know any way to get this information by using the refId and scopeId that would be greatly appreciated.
Adriaan Arnason
Process Engineer
Össur
Sent: 10-24-2023 23:25
Subject: Baseline Source data using VelocityHi Adriaan!
Hope this helps.
Peter Lampacher
MED-EL
Innsbruck
Adriaan Arnason
Process Engineer
Össur
