Authorize API in Jama
Rizwana Fathima
Rizwana Fathima Member Posts: 3
Hi team,
I need below Clarification. Can you please response ASAP..
I am trying to get the Authorize API in Jama but Unable to find anything. Jama document link I referred..
Is there any API request available for an authorization code by redirecting the user to JAMA Connect?
Just for your reference , I saw something similar in Jira For More Information and listed Main points below:
  1. Request authorization code by redirecting the user to the "/rest/oauth2/latest/authorize" page with the following query parameters:
Postman API - "https://atlassian.example.com/rest/oauth2/latest/authorize?client_id=CLIENT_ID&redirect_uri=REDIRECT_URI&response_type=code&state=STATE&scope=SCOPE&code_challenge=CODE_CHALLENGE&code_challenge_method=S256"
  1. This consent screen asks the user to approve the application's request to access their account with the scopes specified in the scope. The user is then redirected to the URL specified in redirect_uri. The redirect includes the authorization code, like in the following example:
Postman API - https://atlassian.example.com/plugins/servlet/oauth2/consent?client_id=CLIENT_ID&redirect_uri=REDIRECT_URI&response_type=code&scope=SCOPE&state=STATE&code_challenge_method=CODE_CHALLENGE_METHOD&code_challenge=CODE_CHALLENGE
Image Reference
  1. With the authorization code returned from the previous request, you can request an access_token, with any HTTP client. The following example uses curl:
Postman API - https://atlassian.example.com/rest/oauth2/latest/token?client_id=CLIENT_ID&client_secret=CLIENT_SECRET&code=CODE&grant_type=authorization_code&redirect_uri=REDIRECT_URI&code_verifier=CODE_VERIFIER
Example response { "access token": "eyJhbGciOiJIUzI1NiJ9.eyJpZCI6IjNmMTQ3NTUzYjg3OTQ2Y2FhMWJhYWJkZWQ0MzgwYTM4In0.EDnpBl0hd1BQzIRP--xEvyW1F6gDuiFranQCvi98b2c", "token_type": "bearer", "expires_in": 7200, "refresh_token": "eyJhbGciOiJIUzI1NiJ9.eyJpZCI6ImMwZTMxYmZjYTI2NWI0YTkwMzBiOGM2OTJjNWIyMTYwIn0.grHOsso3B3kaSxNd0QJfj1H3ayjRUuA75SiEt0usmiM", "created_at": 1607635748 }
I need similar flow in JAMA to authorize code.
Kindly help me to solve this!!!
Rizwana Fathima
SSIN
Chennai
