Add Custom Picklist to Testplan
Hi, I wonder if there is a possibility to add a Custom Picklist to a Test plan. Not sure if Test Plan is treated as an item type and how to "tailor" them.
------------------------------Patrik Swahn
Volvo Autonomous Solutions
Yes, you can add custom fields (such as a custom Pick List field) to a Test Plan.
If you go to the ADMIN -> Organization -> Item_types page, you will see that "Test Plan" is an Item type on which you can perform an "Add field" operation.
Sent: 11-27-2023 02:00
Subject: Add Custom Picklist to TestplanHi, I wonder if there is a possibility to add a Custom Picklist to a Test plan. Not sure if Test Plan is treated as an item type and how to "tailor" them.
Patrik Swahn
Thanks, that worked perfect.
Patrik Swahn
Sent: 11-27-2023 21:19
Subject: Add Custom Picklist to TestplanYes, you can add custom fields (such as a custom Pick List field) to a Test Plan.
Patrik Swahn
If we add the field to a item type. Does it effects to the particular project or all the projects existing in JAMA tool?
santosh kaparthi
Patrik Swahn
Item types in Jama are global to all projects in the Jama instance, so if you add a field to an item type, it appears in all projects that use that item type.
Sent: 02-13-2024 04:26
Subject: Add Custom Picklist to TestplanIf we add the field to a item type. Does it effects to the particular project or all the projects existing in JAMA tool?
santosh kaparthi
Patrik Swahn
