Database reset broke jama
Support had us recreate the SQL database to remove all the trash sample frameworks, before they would schedule the onboarding meeting. Now I have connect-drainer-xxxx pod in error condition and jama doesn't start up. The database appears to have reprovisioned as you might expect. I have deleted the pod and rebooted several times. I tried a redeploy and that fails with backoff limit exceeded.
{"log":" File "/usr/bin/entry", line 269, in u003cmoduleu003e ","stream":"stderr","time":"2023-12-07T00:12:39.855531968Z"} {"log":" main() ","stream":"stderr","time":"2023-12-07T00:12:39.855538468Z"} {"log":" File "/usr/bin/entry", line{"log":"2023-12-07 00:12:39,166 INFO __main__: Starting Connect Drainer ","stream":"stderr","time":"2023-12-07T00:12:39.258826881Z"} {"log":"2023-12-07 00:12:39,258 WARNING shared_lib.manifest: manifest being read in non-strict mode, please refactor this image ","stream":"stderr","time":"2023-12-07T00:12:39.258889981Z"} {"log":"2023-12-07 00:12:39,258 INFO shared_lib.manifest: loading manifest file from /entry/manifest.yaml ","stream":"stderr","time":"2023-12-07T00:12:39.258974482Z"} {"log":"/usr/local/lib/python3.6/site-packages/shared_lib/manifest.py:13: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details. ","stream":"stderr","time":"2023-12-07T00:12:39.268807672Z"} {"log":" return yaml.load(open(self.file_path).read()) ","stream":"stderr","time":"2023-12-07T00:12:39.268843473Z"} {"log":"2023-12-07 00:12:39,268 INFO __main__: Checking if Jama Core is available at http://core:80/rest/tenant ","stream":"stderr","time":"2023-12-07T00:12:39.268850073Z"} {"log":"2023-12-07 00:12:39,699 INFO __main__: Jama Core is available ","stream":"stderr","time":"2023-12-07T00:12:39.700048938Z"} {"log":"2023-12-07 00:12:39,699 INFO __main__: request base url will be: "http://core:80" ","stream":"stderr","time":"2023-12-07T00:12:39.700214639Z"} {"log":"2023-12-07 00:12:39,700 INFO __main__: host url: http://core:80 ","stream":"stderr","time":"2023-12-07T00:12:39.70032114Z"} {"log":"2023-12-07 00:12:39,846 ERROR __main__: problem: provisioning is in an unexpected state: error ","stream":"stderr","time":"2023-12-07T00:12:39.855487067Z"} {"log":"Traceback (most recent call last): ","stream":"stderr","time":"2023-12-07T00:12:39.855524868Z"} {"log":" File "/usr/bin/entry", line 269, in u003cmoduleu003e ","stream":"stderr","time":"2023-12-07T00:12:39.855531968Z"} {"log":" main() ","stream":"stderr","time":"2023-12-07T00:12:39.855538468Z"} {"log":" File "/usr/bin/entry", line 264, in main ","stream":"stderr","time":"2023-12-07T00:12:39.855543868Z"} {"log":" raise exception ","stream":"stderr","time":"2023-12-07T00:12:39.855549668Z"} {"log":" File "/usr/bin/entry", line 245, in main ","stream":"stderr","time":"2023-12-07T00:12:39.855554968Z"} {"log":" if tenant.is_provisioned(): ","stream":"stderr","time":"2023-12-07T00:12:39.855560368Z"}{"log":" File "/usr/bin/entry", line 82, in is_provisioned ","stream":"stderr","time":"2023-12-07T00:12:39.855565568Z"} {"log":" raise RuntimeError("provisioning is in an unexpected state: error") ","stream":"stderr","time":"2023-12-07T00:12:39.855570768Z"} {"log":"RuntimeError: provisioning is in an unexpected state: error ","stream":"stderr","time":"2023-12-07T00:12:39.855576568Z"}------------------------------
Mark Moorcroft
AMA Inc.
Santa Clara CA
I dropped the db a couple more times, then eventually a redeploy finally worked.
Now the error state is:
NAME READY STATUS RESTARTS AGE
activemq-0 1/1 Running 0 35m
connect-drainer-pcppm 0/1 Completed 0 10m
core-0 1/1 Running 0 35m
diff-0 1/1 Running 0 34m
elasticsearch-0 1/1 Running 0 34m
hazelcast-0 1/1 Running 0 35m
kotsadm-85c97cb449-qpwn7 1/1 Running 22 11d
kotsadm-postgres-0 1/1 Running 0 34m
kurl-proxy-kotsadm-5c6bb84446-rgsf6 1/1 Running 8 11d
nginx-0 1/1 Running 0 35m
oauth-0 1/1 Running 0 35m
saml-0 1/1 Running 1 35m
tenant-manager-5nz5w 0/1 Error 0 9m53s
tenant-manager-74csx 0/1 Error 0 10m
tenant-manager-d68dt 0/1 Error 0 10m
tenant-manager-ggt2m 0/1 Error 0 9m33s
tenant-manager-hgn7p 0/1 Error 0 8m53s
Mark Moorcroft
AMA Inc.
Santa Clara CA
Sent: 12-07-2023 11:17
Subject: Database reset broke jamaSupport had us recreate the SQL database to remove all the trash sample frameworks, before they would schedule the onboarding meeting. Now I have connect-drainer-xxxx pod in error condition and jama doesn't start up. The database appears to have reprovisioned as you might expect. I have deleted the pod and rebooted several times. I tried a redeploy and that fails with backoff limit exceeded.
{"log":" File "/usr/bin/entry", line 269, in u003cmoduleu003e ","stream":"stderr","time":"2023-12-07T00:12:39.855531968Z"}{"log":" main() ","stream":"stderr","time":"2023-12-07T00:12:39.855538468Z"}{"log":" File "/usr/bin/entry", line{"log":"2023-12-07 00:12:39,166 INFO __main__: Starting Connect Drainer ","stream":"stderr","time":"2023-12-07T00:12:39.258826881Z"}{"log":"2023-12-07 00:12:39,258 WARNING shared_lib.manifest: manifest being read in non-strict mode, please refactor this image ","stream":"stderr","time":"2023-12-07T00:12:39.258889981Z"}{"log":"2023-12-07 00:12:39,258 INFO shared_lib.manifest: loading manifest file from /entry/manifest.yaml ","stream":"stderr","time":"2023-12-07T00:12:39.258974482Z"}{"log":"/usr/local/lib/python3.6/site-packages/shared_lib/manifest.py:13: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read <a href="https://msg.pyyaml.org/load">https://msg.pyyaml.org/load</a> for full details. ","stream":"stderr","time":"2023-12-07T00:12:39.268807672Z"} {"log":" return yaml.load(open(self.file_path).read()) ","stream":"stderr","time":"2023-12-07T00:12:39.268843473Z"}{"log":"2023-12-07 00:12:39,268 INFO __main__: Checking if Jama Core is available at <a href="http://core:80/rest/tenant " ,"stream":"stderr","time":"2023-12-07t00:12:39.268850073z"}"="">http://core:80/rest/tenant ","stream":"stderr","time":"2023-12-07T00:12:39.268850073Z"}</a>{"log":"2023-12-07 00:12:39,699 INFO __main__: Jama Core is available ","stream":"stderr","time":"2023-12-07T00:12:39.700048938Z"}{"log":"2023-12-07 00:12:39,699 INFO __main__: request base url will be: "http://core:80" ","stream":"stderr","time":"2023-12-07T00:12:39.700214639Z"}{"log":"2023-12-07 00:12:39,700 INFO __main__: host url: <a href="http://core:80 " ,"stream":"stderr","time":"2023-12-07t00:12:39.70032114z"}"="">http://core:80 ","stream":"stderr","time":"2023-12-07T00:12:39.70032114Z"}</a>{"log":"2023-12-07 00:12:39,846 ERROR __main__: problem: provisioning is in an unexpected state: error ","stream":"stderr","time":"2023-12-07T00:12:39.855487067Z"}{"log":"Traceback (most recent call last): ","stream":"stderr","time":"2023-12-07T00:12:39.855524868Z"}{"log":" File "/usr/bin/entry", line 269, in u003cmoduleu003e ","stream":"stderr","time":"2023-12-07T00:12:39.855531968Z"}{"log":" main() ","stream":"stderr","time":"2023-12-07T00:12:39.855538468Z"}{"log":" File "/usr/bin/entry", line 264, in main ","stream":"stderr","time":"2023-12-07T00:12:39.855543868Z"}{"log":" raise exception ","stream":"stderr","time":"2023-12-07T00:12:39.855549668Z"}{"log":" File "/usr/bin/entry", line 245, in main ","stream":"stderr","time":"2023-12-07T00:12:39.855554968Z"}{"log":" if tenant.is_provisioned(): ","stream":"stderr","time":"2023-12-07T00:12:39.855560368Z"}{"log":" File "/usr/bin/entry", line 82, in is_provisioned ","stream":"stderr","time":"2023-12-07T00:12:39.855565568Z"}{"log":" raise RuntimeError("provisioning is in an unexpected state: error") ","stream":"stderr","time":"2023-12-07T00:12:39.855570768Z"}{"log":"RuntimeError: provisioning is in an unexpected state: error ","stream":"stderr","time":"2023-12-07T00:12:39.855576568Z"}
Mark Moorcroft
AMA Inc.
Santa Clara CA
