Finding items without a category
We are trying to find items in a project that don't have a category assigned to them. The advanced filters allow us to find items where category "is equal to" or "is not equal to" a specific category, but it doesn't let us find items that don't have any categories assigned, unless we enter multiple conditions of "is not equal to" and then add one per category that we have in the project, and this list can be long. There is no option to choose "is empty".
Does anyone have a workaround for this? or should we just submit this as an idea?
------------------------------Lita Gribben
Blue Origin
My workaround for tags is keywords contains !tags:*
It seems not to work for categories ... or I do not know to write the "keyword" -> there is a feature request for this : need the way to specify a category (path) in an advanced filter via keyword rule
Sent: 03-01-2024 07:35
Subject: Finding items without a categoryWe are trying to find items in a project that don't have a category assigned to them. The advanced filters allow us to find items where category "is equal to" or "is not equal to" a specific category, but it doesn't let us find items that don't have any categories assigned, unless we enter multiple conditions of "is not equal to" and then add one per category that we have in the project, and this list can be long. There is no option to choose "is empty".
Lita Gribben
Blue Origin
SICK AG0 -
Hello
our workaround is to use a context sensitive velocity report with a link back to Jama Connect as search term (as attachment also the complete report with better formatting):
#set( $docus = $documentSource) #set( $jamaProjectURL = $baseUrl + "/perspective.req#/items/") #set( $searchURL = $baseUrl + "/perspective.req#/search?term=" ) #set( $api_ids = [] ) #set( $quote = '"' ) <html> <body> <table> <thead><tr> <th>Requirement</th> <th>Name</th> </tr></thead> <tbody> #foreach( $vDoc in $documentList ) #set( $doc = $vDoc.document ) #set( $categories = []) #set( $categories = $docus.getAllCategoryPathsByDocumentId( $doc.id )) #if( $categories.size() == 0 ) <tr><td><a href='$jamaProjectURL$doc.id.toString()?projectid=$project.id.toString()' target='_blank'>$doc.id.toString(): $doc.documentKey</td> <td>$doc.name</td> </tr> #if( $api_ids.add( $doc.id.toString()) ) #end #end #end </tbody></table> #foreach( $api_id in $api_ids ) #set( $searchURL = $searchURL + "id:${quote}$api_id${quote}" ) #if( $foreach.hasNext ) #set( $searchURL = $searchURL + " " ) #else #set( $searchURL = $searchURL + "&scope=PROJECT&projectId=" + $project.id.toString() ) #end #end <p><a href='$searchURL$' target='_blank'>Open Requirements in Jama Connect</a></p> </body> </html>
Iwan Kutter
Requirement Engineer
Bernina International
Lita Gribben
Blue Origin
Iwan Kutter
Bernina International0
