PUT testruns to JAMA is not updating the description
Josy Kuriakose
Member Posts: 1
I am using the REST APIs to create a new testCycle and publish test results to JAMA.
When using "PUT /testruns/{id}" API; I use the data as given below.
<em> data = {</em>
<em> "fields": {</em>
<em> "testRunStatus": "PASSED",</em>
<em> "description": "Sample Test description",</em>
<em> }</em>
<em> }</em>
And send it to given test run as given below.
jama_client.put_test_run(test_run_id=test_run['id'], data=json.dumps(data))
The testRunStatus gets updated successfully. But the "description" never gets updated. When I get the same test run; I see description as "".
'fields': {....., 'testRunSetName': 'Automated_Tests', 'description': '', 'modifiedDate': '2024-03-05', 'testRunStatus': 'PASSED', 'project': 81, 'forcePassed': False, 'executionDate': '2024-03-05'}
Can I get some help with this issue?
Josy Kuriakose
10X Genomics
CA
