Jama Connect Interchange™ Release Notes, Version 1.4
Release Date: 2022/11/11
What’s New in Version 1.4
Jama Connect Interchange version 1.4 includes the following enhancements:
New integration with Jira Data Center
Jama Connect Interchange now supports integration between Jama Connect and Jira Data Center. Jira Data Center is the self-hosted offering from Atlassian Jira. Jama Connect Interchange formally supports Jira Data Center versions 8.13 and later.
The integration with Jira Data Center includes the same features and capabilities as the integration with Jira Cloud.
To license the Jama Connect Interchange — Jira Data Center integration, contact your Customer Success Manager.
Minor Enhancements
The 1.4 release includes the following minor enhancements:
  • New mappable field for Jama Set ID — On the Field Mappings page, you can now map the Jama Set ID. This allows you to display an item’s Jama Set ID in a custom field in the Jira issue.
    To map the Jama Set ID, select Jama Set ID – Text (read only) in the left drop-down list on the Field Mappings page. Typically, you map this field to a custom text field (type = short text) in Jira.
    The Jama Set ID can also be mapped for Excel Functions integrations.
  • Auto-refresh for Links and Logs pages — The Links and Logs pages are now automatically refreshed every 10 seconds. This means you no longer need to refresh these pages manually to see updates.
  • Frequency options updated for Jira integrations — The 3- and 5-second frequency options have been removed from Jira Cloud and Jira Data Center integrations. If you had one of these options selected for a Jira integration, it is automatically changed to 15 seconds when your instance is upgraded to the 1.4 release.
  • Excel Functions supports null values — Excel Functions integrations now run as expected if a mapped field contains a null value.
  • Jira Status to Jama Text mapping now supported — You can now map the Jira Status field to a Jama Connect text field. Previously, the Jira Status field could only be mapped to a Jama Connect single-select field.
  • Improvements for self-hosted instances — Several improvements have been made for self-hosted Interchange instances, including better error handling and improved syncing of rich text fields.
  • Airgap support — Jama Connect Interchange can now be installed on self-hosted environments that are airgapped.
