Synchronization of Items within one project
I want to synchronize items within one project and get the following error message:
"Your organization enforces a policy that items cannot be reused and synchronized within the same project. Please select a different project or contact your organization administrator."
I do have admin rights. Could you tell me, how or where to allow synchronizations within a project?
Thanks, Aaron
  • Iwan Kutter
    Iwan Kutter Member Posts: 26
    Hello
    I'm not sure if this is the same issue, but if you uncheck "Allow multiple global IDs in the same project" you get the following message when you want to reuse items in the same project:
    This can be enabled in in the tab "Details" under Organization Admin by activate following setting:
    • Allow multiple items with the same global ID in a single project
    As soon this is activated, we can reuse and sync items in the same project.
    Best regards Iwan
    Iwan Kutter
    Requirement Engineer
    Bernina International
  • Aaron Riede
    Aaron Riede Member Posts: 7
    Thanks Iwan, that was it!
