How to add a custom field into a velocity report
I have a custom text field named "legacy_id" that I am trying to add as a new column in a velocity trace report. When using:
"td rowspan=$span class=$contentStyle>$!source.legacy_id</td>"
the column is not populated with the data in the report. If I substitute "source.legacy_id" for a different predefined field such as "source.text1", the report shows the data. What do I need to do to get the custom field I have created to display in the velocity report?
Hi Dave,
please use the uniquefieldname$itemtypeid, like legacy_id$4711. 4711 is the API-ID you can find under admin-organization-item types for the desired item type
SICK AG1 -
Thanks for this reply Alessandro, but that doesn't seem to work for me either:
I based my report off the 2up2down one in github but trying to add custom fields I try:
<td style='border-top: $borderTop;'>$doc.software_function_area$163</td>
And it just shows up as "$doc.software_function_area$163" in the excel cell
Just tried these too:
<td style='border-top: $borderTop;'> $doc.get("software_function_area") A </td> <td style='border-top: $borderTop;'> ${doc["software_function_area"]} B </td> <td style='border-top: $borderTop;'> ${doc["software_function_area$163"]} C </td> <td style='border-top: $borderTop;'> $doc.get("software_function_area$163") D </td>
and they also don't work
Andrew MacCormack
LumiraDX0 -
It appears my previous comments somehow got deleted?
Andrew MacCormack
LumiraDX0 -
In short, Alessandro's comment doesn't seem to work for me in an Excel. I tried:
and none worked
Andrew MacCormack
LumiraDX0 -
For velocity reports you can try: $velocityReportUtil.getValueForField($source, "legacy_id", $dateFormat).
The $dateFormat can just be an empty variable.
1 -
Looks like this forum software doesn't like velocity code somehow, it keeps removing it when I try and post, so here's a pic:
OK, the picture upload also doesn't work. sigh
Here's a gist link instead:
Andrew MacCormack
LumiraDX0 -
In the end I wanted to have a lot of custom fields in the report so I did this to make a dictionary of the whole lot:
#set ( $customFieldValueMap = {} )
#foreach( $fieldObj in $doc.getCustomFields() )
## Attempt to do lookup
#set ($fieldValue = $lookupDao.getLookup($mathTool.toInteger($fieldObj.textValue)).name)
## If it fails, use as is
#if (!$fieldValue)
#set ($fieldValue = $fieldObj.textValue)
#end
#set ( $success = $customFieldValueMap.put($customFieldById[$fieldObj.getFieldId()], $fieldValue))
#end
^ Seems that the pre-formatted thing strips leading whitespace, which is kind the point of preformatted!
Andrew MacCormack
LumiraDX0 -
#set ( $customFieldValueMap = {} ) #foreach( $fieldObj in $doc.getCustomFields() ) ## Attempt to do lookup #set ($fieldValue = $lookupDao.getLookup($mathTool.toInteger($fieldObj.textValue)).name) ## If it fails, use as is #if (!$fieldValue) #set ($fieldValue = $fieldObj.textValue) #end #set ( $success = $customFieldValueMap.put($customFieldById[$fieldObj.getFieldId()], $fieldValue)) #end
In the end, I'm using a lot of custom fields so wrote the above to create a dictionary of them all
Andrew MacCormack
LumiraDX0 -
Just tried all of these and they don't work either:
Andrew MacCormack
LumiraDX0 -
Just tried all of these and none work either:
Thanks for any tips
Andrew MacCormack
LumiraDX0 -
$doc.get("software_function_area") ${doc["software_function_area"]} ${doc["software_function_area$163"]} $doc.get("software_function_area$163")
and none work
Andrew MacCormack
LumiraDX0 -
Andrew MacCormack
LumiraDX0 -
Looks like suddenly all the posts that went missing are back! 🤔
Andrew MacCormack
LumiraDX0
