Using Jama Connect to Integrate External Data Sources: Best Practices and Difficulties
Hello Everyone 🤗,
I'm contacting you in order to learn more and exchange experiences on integrating other sources of data with Jama Connect.
Our team is currently investigating ways to integrate other external data sources, such as third-party databases and APIs, to improve our Jama Connect implementation. In particular, we want to know about the best practices, possible obstacles, and potential dangers to watch out for during this phase of integration.
I have the following specific queries:
Best Practices: How should external data sources be integrated with Jama Connect?🤔Do you suggest any specific tools or approaches to guarantee a seamless integration?🤔
Typical Obstacles: What are some typical obstacles or problems that you've run into while using outside data sources?🤔How did you handle these difficulties?🤔
https://help.jamasoftware.com/ah/en/reference/best-practices-and-guardrails.html
Performance-Related Matters: What effects does Jama Connect's integration of external data sources have on its performance?🤔Can you provide any techniques or tips for performance optimisation?🤔
Security & Data Privacy: When integrating outside sources of data, what precautions should be taken to protect data security and privacy?🤔Are there any particular standards for compliance that we need to be aware of?🤔
Success Narratives: Could you share what happened if you have successfully merged external data sources using Jama Connect?🤔Any advice or insights from your deployment would be very valued.
Anyone with knowledge of this who can provide guidance or minitab insights is welcome to get in touch with me. We will be able to better our integration approach with the help of your significant experience.
Thank you 🙏 in advance.
  • Lita Gribben
    Lita Gribben Member, Data Exchange, Jama Connect Interchange™ (JCI) Posts: 90
    Unfortunately I don't have a success story to share yet, but commenting to bump up this topic.
    Our organization is also evaluating options for this. JCI and PlanView seem to have similar functionality as well as the same limitations.
    Are you looking at doing custom integration using the API?
