Matrix of Pick Lists
I searched for an answer for this, so if this is a repeat question … my apologies.
Is there a way to create a matrix of Pick Lists. For example, if I have a number of temperatures, T(min), T(nom), T(max) that I would want to be side by side instead of one on top of the other, it seems like this would allow better use of space within Jama.
Also, when creating a Pick List, is there a way to populate the pick list in a less tedious way than separate entries for a given pick list? Is there any way to give the range of values, say Val(min), Val(max), and increment?
