Is there a way to import "Item of Type" content into JAMA using excel?
samoshah
Member, Jama Connect Interchange™ (JCI) Posts: 1
The field mappings when importing won't even show "Item of Type" content - Is there a way to do this? I have several hundred rows in my set and making a selection for each one of them will take hours. 😥
1
Bridget Dowling Member, Medical Devices & Life Sciences Solution, Jama Validation Kit (JVK) + Functional Safety Kit (FSK) Posts: 10
This would be very useful if it can be done.
I don't see a direct way to import "Item of Type" content into Jama using Excel.
A possible workaround to consider is to create a custom field with Field Type of URL
You can map this URL field to the column header that contains all your text references to the items with hyperlink embedded.
The difference is that you won't be able to change the content of this URL custom field the same way as the Item of Type picklist field.
