Allow Upstream Traceability in Coverage Explorer
[Deleted User] Posts: 4
edited October 2016 in
This is a fundamental capability necessary for government contracting work.  Our customers require us to submit our test documentation to them for approval. Part of that documentation is an upward look (from a test case to the requirements).  When reviewing a test case, the first thing that gets looked at is the allocated requirements.  To provide them the RTM and require them to hunt for the requirements allocated to the case in question is falling way short.  To fill that gap, the test team has to manually manipulate the RTM (fill in the blanks, sort by test case, remove duplicates).  this is something every requirements management software should be able to do.
Note: This conversation was created from a reply on: Is there a way to trace upstream coverage?.
